mts Posted April 19, 2006 Report Share Posted April 19, 2006 Originally posted by "Duncan" MODELGUIDE mazda millenia - 1995-2002 Not exactly a replacement for the 929, and not exactly a giant step up from the 626 it shared major parts with, Mazda's conflicted Millenia luxury sedan ended up becoming something special on its own terms. Known by most for its spectacular styling and the unique Miller Cycle engine, it has become a cult classic among both Mazda fans and lovers of interesting automobiles. The Millenia only endured one generation from 1995-2002 (the "TA" model), but with a major facelift and update during that time. Watch this space for a full report! -- Duncan M. MAZDA MILLENIA PAINT COLORS This info comes from a site called PaintScratch.com, sellers of touch-up kits and paint packages that match original factory colors. All I've done is compiled the paint codes for each year - it's up to you to check your car and see what matches. You can find your color by simply opening up your driver door and, on the info sticker on the door jamb, looking for a two- or three-digit paint code. 1995 MAZDA MILLENIA 1H - Steel Gray Mica Clearcoat 4F - Champagne Silver Mica Clearcoat 5U - Gardenia White Mica Tri-Coat A5 - Satellite Blue Mica Clearcoat A7 - Art Vin Red Mica Clearcoat PX - Brilliant Black PZ - Brilliant Black Clearcoat Z8 - Deep Sea Mica Clearcoat 1996 MAZDA MILLENIA 4F - Champagne Silver Mica Clearcoat 5U - Gardenia White Mica Tri-Coat A7 - Art Vin Red Mica Clearcoat PX - Brilliant Black PZ - Brilliant Black Clearcoat Z8 - Deep Sea Mica Clearcoat Z9 - Bluish Gray Mica Clearcoat 1997 MAZDA MILLENIA 11Q - Excellent Green Mica Clearcoat 12N - Indigo Blue Metallic Clearcoat 15X - Mid Green Mica Clearcoat 15Y - Autumn Red Mica Clearcoat 4F - Champagne Silver Mica Clearcoat 5U - Gardenia White Mica Tri-Coat PX - Brilliant Black PZ - Brilliant Black Clearcoat 1998 MAZDA MILLENIA 11Q - Excellent Green Mica Clearcoat 12K - Twilight Blue Mica Clearcoat 12N - Mid Green Mica Clearcoat 15Y - Autumn Red Mica Clearcoat 4F - Champagne Silver Mica Clearcoat 5U - Gardenia White Mica Tri-Coat PZ - Brilliant Black Clearcoat 1999 MAZDA MILLENIA (note new two-tone combinations) 12K - Twilight Blue Mica Clearcoat 15X - Mid Green Mica Clearcoat 15Y - Autumn Red Mica Clearcoat 17W - Snow White Mica Clearcoat 18J - Grace Green Mica Clearcoat 20D - Gentry Silver Metallic Clearcoat (used only as lower two-tone color) 4F - Champagne Silver Mica Clearcoat PZ - Brilliant Black Clearcoat 19A - (Two-Tone) 17W Snow White Mica Clearcoat / 4F Champagne Silver Mica Clearcoat 20E - (Two-Tone) PZ Brilliant Black Clearcoat / 20D Gentry Silver Metallic Clearcoat 2000 MAZDA MILLENIA (note that some previous codes have changed) 12K - Twilight Blue Mica Clearcoat 15X - Mid Green Mica Clearcoat 15Y - Autumn Red Mica Clearcoat 17W - Snow White Mica Tri-Coat 18J - Grace Green Mica Clearcoat 20D - Gentry Silver Metallic Clearcoat (used only as lower two-tone color) 22K - Passion Red Mica Metallic Clearcoat 4F - Champagne Silver Mica Clearcoat A3F - Brilliant Black 19A - (Two-Tone) 17W Snow White Mica Tri-Coat / 4F Champagne Silver Mica Clearcoat A3H - (Two-Tone) A3F Brilliant Black / 20D Gentry Silver Metallic Clearcoat 2001 MAZDA MILLENIA 17W - Snow White Mica Tri-Coat 18J - Grace Green Mica Clearcoat 20D - Gentry Silver Metallic Clearcoat 22K - Passion Red Mica Metallic Clearcoat 22R - Platinum Silver Metallic Clearcoat 4F - Champagne Silver Mica Clearcoat A3F - Brilliant Black 19A - (Two-Tone) 17W Snow White Pearl Tri-Coat / 4F Champagne Silver Pearl Clearcoat A3H - (Two-Tone) A3F Brilliant Black / 20D Gentry Silver Metallic Clearcoat 2002 MAZDA MILLENIA 18J - Grace Green Mica Clearcoat 19A - Snow White Mica Tri-Coat (used only as upper two-tone color) 20D - Gentry Silver Metallic Clearcoat 22K - Passion Red Mica Metallic Clearcoat 22R - Platinum Silver Metallic Clearcoat 25D - Snowflake Mica Tri-Coat 4F - Champagne Silver Mica Clearcoat A3E - Classic Red Clearcoat A3F - Brilliant Black 19A - (Two-Tone) 17W Snow White Mica Tri-Coat / 4F Champagne Silver Mica Clearcoat A3H - (Two-Tone) A3F Brilliant Black / 20D Gentry Silver Metallic Clearcoat 26G - (Two-Tone) 25D Snowflake Mica Tri-Coat / 4F Champagne Silver Mica Clearcoat 1995-2002 Mazda Millenia Specifications Wheelbase: 108 inches Overall Length: 190 inches Overall Width: 70 inches Overall Height: 55 inches Curb Weight (S): 3391 lbs. Curb Weight (L): 3232 lbs. Curb Weight (base): 3216 lbs. Interior Volume: 94 cubic feet Trunk Volume: 13.3 cubic feet Fuel Capacity: 18 gallons Seating Capacity: 5 Front Head Room: 39.3 inches Front Leg Room: 43.3 inches Rear Head Room: 37.0 inches Transmission: Electronically-Controlled 4-speed Automatic Country of Manufacture: Japan Drive Wheels: Front-Wheel Drive Steering: Rack and pinion type with engine rpm sensing variable assist power steering Brakes: ABS with dual diagonal hydraulic circuits, 10.8 inch ventilated front discs, 11.3 inch rear discs Wheels: Aluminum Alloy - 15x6.0JJ +60mm (205/65), 16x6.5JJ +55mm (215/55), 17x7.0JJ +50mm (215/50) Coefficient of drag: 0.28 Quote Link to comment Share on other sites More sharing options...
///BHRpowered Posted June 16, 2010 Report Share Posted June 16, 2010 Differences - telling years apart. *Under construction, I'm hoping when its done to have pics of every item mentioned. 1995 2.5 L 15" rims with large center cap 1 piece projector headlights Solid yellow turn signal lights Special keyless entry FOB with full logo Badging in smallest font used on tail gate plate External power antenna Bose system with dual extra large 80's style knobs, Cass with CD changer control Leather trimmed shifter and center console 2.3 S Differences Leather and keyless entry standard 16" rims with large center cap Limited edition colors Gold badging 1996 Changes Keyless entry changed to 96-00 style (No logo) 1997 Changes Shifter position deleted from gauge cluster 2 piece headlight/marker lights Clear glass lense headlights Upgraded bose system with CD "Winter package" for 2.3 Grill logo changed Larger logos moved to upper trunk lid from trunk plate 16" rims with small center caps Cup holder redesign (moved to pop out center console) In-glass antenna 1998 Changes Mazda logo changed to current "Flying M" 1999 Changes 2.5 L Redesigned 16" double spoke rims Clear turn signal lights Clear tail lights Chrome added around license plate area Chrome door sill lettering "Millenia" 2.3 S All new 17" 5 spoke rims, alloy or chrome Tu-tone Paint option (Black/gray or White/beige) 2000 Changes Various interior and exterior chrome added to trim areas and buttoms Grill slots slightly enlarged Millennium Edition (ME) introduced in Red or Silver ME edition includes black dash and dark gray suede interior ME edition includes chrome rims as standard 2001 Changes 2.5 "premium model" introduced -denoted as the most basic model "P" Gauge cluster redesign using electroluminasint gauges Leather returns to center console and shifter Face lift includes new front bumper New larger grill New projector headlights (plastic) Halogen reflector fog lights Redesigned tail lights Redesigned trunk plate SLIGHTLY larger brake pads Larger brake ducts and dust cover 30% torsion stiffing Sway bar added (will fit all years) Addition of Side Impact Air-bags Cig lights and heater seat buttons relocated Keyless entry FOB slightly altered Redesigned 16" rims (P and L only) 2.3 S Chrome trim ring around shifter Optional 6-disc in-dash cd changer Tu-tone steering wheel 2002 Changes Special edition "SE" introduced, denoted by solid black exterior, black chrome rims, all black interior except for seats which remain beige Final year of production worldwide **We know certain years offered both a 5-speed manual transmission as well as a 2.0 liter engine overseas, though I cannot confirm what years** Quote Link to comment Share on other sites More sharing options...
