929 Trunk Lift Support Replacement
Originally posted by "Dmeetro" hmm well i guess he didnt reply and i h8 2 steal to torch from him but oh well heres a pm he sent me back about this about a month ago
"The strut was provided by
1/800-548-2549 Ext.232
Fax # 310/898-3084
WWW.TOKICOGASSHOCKS.COM
The strut model number is: Y2044
Please note the following:
1) These struts are much more powerful than the original. Therefore, I replaced only one strut, and left the original strut on the other side. It turned out to be just perfect. Both new struts was too much force to open and close.
2) You will need to remove one strut, and drill out the bracket on the bottom such that the new strut will accept a new bolt and nut through the eyelet. The original struts have swivel heads, the replacement one has eyelets that you bolt through. This is not a problem, and this model will extend the hood just as much as the original struts.
Let me know if you need anything else, and good luck."
