mts Posted April 20, 2006 Report Share Posted April 20, 2006 Originally posted by "The_Saint" Mazda 929 Year: 1992 to 1995 Jump GRD and TEN in the diagnosis connector under the hood with a wire With the ignition switch on and count the flashs of the check engine light. Trouble Code Identification Trouble Shooting the error: 01 Ignition Pulse No Data 02 Crank Angle Sensor, Ne Signal 03 Crank Angle Sensor, G Signal 04 Distributor, Ne 1 Signal 05 Knock Sensor 06 Speedometer Sensor 07 Knock Sensor, RH Side See Error code 5 08 Air Flow Meter 09 Water Thermo Sensor 10 Intake Air Thermosensor in Air Flow meter 11Intake Air Thermo Sensor Dynamic Chamber 12 Throttle Sensor (Full Range) 13 Pressure Sensor No Data 14 Atmospheric Pressure Sensor If code 14 is present, replace ECU. 15 O2S 16 EGR Switch 17 Feedback System 18 Throttle Sensor, Narrow Range No Data 20 Metering Oil Pump Position Sensor No Data 23 Fuel Thermo Sensor See Error code 15 25 Solenoid Valve, Pressure Regulator Control No Data 26 Metering Oil Pump, Stepping Motor 27 Metering Oil Pump No Data 28 EGR Vaccum Solenoid Valve 29 EGR Vent Solenoid Valve 30 Cold Start Injector Relay 31 Solenoid Valve, Relief No Data 32 Solenoid Valve, Switch No Data 33 Port Air Solenoid Valve No Data 34 Solenoid Valve, Idle Speed Control 36 & 37 Right/Left Oxygen Sensor Heater Relay 38 Solenoid Valve, Accelerated Warm Up System No Data 39 Solenoid Valve, Relief 2 No Data 40 Solenoid Valve, Purge Control No Data 41 Variable Resistance Induction System 42 Solenoid Valve, Turbo Pre Control No Data 43 Solenoid Valve, Wastegate Control No Data 44Solenoid Valve, Turbo Control No Data 45 Solenoid Valve, Charge Control No Data 46 Solenoid Valve, Charge Relief No Data 50 Solenoid Valve, Double Throttle Control No Data 51 Fuel Pump Relay No Data 54 Air Pump Relay No Data 65 A/C Imput Signal 71 Injector, Front Secondary No Data 73Injector, Rear Secondary No Data 76 Slip Lockup Off Signal No Data Torque Reduced Signal No Data Clearing Codes: After you have repaired or replace any parts that you believe was the cause of the ECU error code, you will need to clear the code from the ECU. 1) Disconnect negative battery cable. Depress brake pedal for at least 5 seconds. Reconnect battery cable. 2) Ground test connector with jumper wire. Turn ignition on, but do not start engine for 6 seconds. Operate engine at 2000 RPM for 2 minutes. Verify no codes are displayed. Link to comment Share on other sites More sharing options...
