latinopikachu Posted January 25, 2007 Report Share Posted January 25, 2007 -------------------------------------------------- Outline Cross-Sectional View System Circuit Specifications Outline of Construction Outline of Operation Featured Parts and their Functions Relation of Electronic Component and Control System Operation of Components -------------------------------------------------- -------------------------------------------------- Electronic Control Input Signal System Throttle Position Sensor, Closed Throttle Position Sensor Throttle Position Sensor, Closed Throttle Position Sensor II Misc Control Misc Control Output Control System Shift Solonoid A and B Lockup Solenoid Valve Dropping Resistor Other Components -------------------------------------------------- -------------------------------------------------- Control System Transmission Control Module Drive Pattern Selection Control Shift Control Theoretical Circuit Diagram Engine Braking Control (Overrunning Clutch Control) Line Pressure Control Line Pressure Control II Lockup Control Lockup Control II Lockup Control III Lockup Control IV Lockup Control V Torque Reduction Control Neutral-D Select Output Control On-Board Diagnosis System Malfunction Indication Malfunction Indication II -------------------------------------------------- Link to comment Share on other sites More sharing options...
